[DONE] Automatic and manual supports at once
Posted: Tue Mar 03, 2015 8:13 am
by AndersE
I sometimes want to automatically generate supports AND add my own, but it does not seem to work that way.
Either automatic supports OR manually made, not both at the same time.
I want both..
Re: Supports req, or already in the software?
Posted: Tue Mar 03, 2015 9:45 am
by SockMonkey
Works for me, I just tested it out, automatically generated supports, and then added in my own structures, and when the G-Code was generated it included both supports structures. I'm using 2.2.2 on a Mac
Posted: Tue Mar 03, 2015 11:55 am
by dsegel
When you're in the "Manually Define Support" dialog box, if you click "Apply based on overhang angle" it will put in the supports that would be generated automatically. You can then add or remove any support you want.
