BUG: Support layers stopping 1 layer multi processes
Posted: Fri Mar 13, 2015 8:59 pm
by madeinoz
Hi Guys,
When using more than 1 process I'm finding that the support layer is stopping 1 layer short of the top of the current process, this is causing problems with the next process.
using version 2.2.2 OS X
See screen shot of where two processes begin/end
Re: BUG: Support layers stopping 1 layer multi processes
Posted: Sat Mar 14, 2015 1:17 am
by madeinoz
Here is factory file incase I'm doing something completely wrong
Posted: Sat Mar 14, 2015 12:05 pm
by SockMonkey
madeinoz wrote:Here is factory file incase I'm doing something completely wrong
If I'm looking at this correctly, the Top/Bottom Nylon processes are for the support material (second extruder) and the process, "Process 1" is for the model, right? I turned off support generation on the Process 1
In the "Bottom Nylon" process, in the support tab, set the Upper Vertical Separation Layers to 0, and in the "Top Nylon" process, set the Bottom Vertical Separation Layers in the support tab to 0.
Posted: Sun Mar 15, 2015 2:06 am
by madeinoz
Not the two processors were for the same extruder, I wanted to speed things up on the solid layers. So just one extruder for support and model, both nylon.
Posted: Sun Mar 15, 2015 11:14 am
by palawanisland
might be :
check edit process setting -> support tab -> seperation from part group -> upper / lower vertical separation..
Posted: Sun Mar 15, 2015 9:50 pm
by madeinoz
palawanisland wrote:might be :
Thanks for that will test the setting
