plasticHead
CubeX
Could someone please explain how you use this software with a CubeX.
Thanks.
Simplify3D
Site Admin
Re: CubeX
I'm attaching a .fff file that another customer was using with their CubeX. We don't have one in-house, so please use this with caution. You would also need to go to Tools > Firmware Configuration and select the included CubeX Firmware profile.
After those changes, Creator should be producing the correct G-Code for that machine. I know you can also load G-Code into the default CubeX software if you want to validate it that way, but you should be good to try it out on the machine after that.
CubeX.fff
(2.45 KiB) Downloaded 1002 times
galvarez
Re: CubeX
Simplify3D wrote:I'm attaching a .fff file that another customer was using with their CubeX. We don't have one in-house, so please use this with caution. You would also need to go to Tools > Firmware Configuration and select the included CubeX Firmware profile.
Hi, im currently using Kisslicer to print with my CubeX Trio, im looking for a software that will let me print with the three extruders.
Will S3D allow me to do that ?
Regards !
