infill mess
Posted: Mon Mar 16, 2015 7:48 am
We are using simplify3D. Printing the infill becomes a mess. The infill lines don't stick to the underlying level well enough. See picture.
ABS, bed 80 degrees, nozzle 230 degrees, infill speed 50%.
Fiddling with the 23000 parameters doesn't seem to improve much.
The problem has two aspects; de thin lines don't stick to the layer well enough, but the nozzle also runs through the lines in the other direction it just made, because they are in one plane. This seems to be a conceptual flaw of the pattern in Simplify3D; I wish we could choose from patterns that don't collide, like Slicr3. The problem appears more to the middel of our object. With smaller objects no problem.
It is as in the middle there is too much cooling involved for the thin line infill to stick to the underying layer and then the lines are too easely rammed of their spot when the nozzle makes the lines in the other directions. After a while the priner prints in the air and feeding stops...
Does anyone has the same kind of problem?
Rene
Rene
