I'm using a Dremel Idea Builder (rebranded Flashforge Dreamer) and have noticed that with most of my PLA prints there tends to be much more warping or curling of thin unsupported layers on the LEFT side. There happens to be a cooling fan mounted on the left side print head assembly that blows horizontally from left to right. This is in addition to the two fans mounted directly on either side of the nozzle heat sink that blow air from front to back.
I'm wondering if the airflow generated by this sideways mounted fan could be a factor in the asymmetrical nature of my warping issues. I don't usually have any problems with first layer adhesion since I started putting a light coat of Cube Glue on the tape before each job, but areas like the beginnings of ears on my portrait busts usually start curling up enough to eventually bump into the nozzle on subsequent layers.
Does anyone have any advice or thoughts on how to reduce this effect without the need to completely disable the fan? I would assume turning it off might have an even more detrimental impact.
Thanks,
M
