blistik
Print pausing between infill and layers for 10 secs
Since v 5.1.1, without any changes to the printer profile (Leapfrog Bolt Pro) the print is pausing between every infill and layers transition for about 10 secs. Very odd. :|
Any ideas on preventing this? I see no settings to even do this if you wanted to.
the only custom scripts are for starting and ending, and one replace: {REPLACE "Z = " "Z "}
thanks in advance
Blistik
Re: Print pausing between infill and layers for 10 secs
Perhaps you entered one of the speeds in mm/min as a mm/sec value instead? For example, telling the extruder to retract at 40 mm per MINUTE would definitely cause a very long pause at the end of each loop.
blistik
thanks, that was it.
I wonder why they changed it from mm/sec.
No problem multiply by 60
It's a preference option, so you can set it to display whatever you want (go to Tools > Options, and change the "Speed Units" setting).
