Modify bed and extruder pre-heat time ?
Posted: Wed Jul 05, 2023 1:28 pm
by DranerB
As said in the subject line, I would like to modify this, but in the Starting script, I only have actions starting after G28, while heating is done before. So where can I access these settings to modify them ?
Thanks for your help.
Bernard
Re: Modify bed and extruder pre-heat time ?
Posted: Thu Jul 06, 2023 11:25 am
by S3D-Jason
You can put the preheating commands in your starting script, and then the software knows not to add those commands beforehand.
For example you could put this for your starting script:
G28 ; home axes
M109 S[extruder0_temperature] T0 ; for for extruder to preheat
If you use that script, you will see that S3D no longer adds its own M104/M109 commands at the top of the file, since it knows you are handling those commands manually in the starting script.
Posted: Thu Jul 06, 2023 6:15 pm
by DranerB
S3D-Jason wrote: ↑Thu Jul 06, 2023 11:25 am
G28 ; home axes
Did not know this. Thanks, I'll try it.
