[ADDED] Auto max speed based on volumetric max
Posted: Sun Jul 16, 2023 2:36 am
by Image_Engine
Since max feed rate is ultimately volumetric, can we get a feature in S3D (similar to 'other'slicers Auto Speed function) so that it governs the actual speed based on that?
Would be so helpful
EDIT? Sorry I put in the wrong category but cant edit to move it
Re: Auto max speed based on volumetric max
Posted: Mon Jul 17, 2023 9:39 am
by S3D-Jason
I believe this was already added in the V5 software. Go to Edit Process Settings > Speeds tab, and enable the "Reduce print speed for excessively high flow rates" option. You can then set the desired max flow rate for each extruder and the software will automatically lower the speed to make sure that flow rate is not exceeded.
Posted: Mon Jul 17, 2023 5:12 pm
by Image_Engine
Thanks again
Im probably not reading the title properly
So eg I could simply set speeds except eg outline perim/layer etc and that option will globally override and act as a governor? Correct
Posted: Tue Jul 18, 2023 2:14 pm
by S3D-Jason
You can set the speeds to whatever you want, but if you enable the "Reduce print speed for excessively high flow rates" option then the software will automatically lower the speeds in the output file to avoid exceeding the flow rate that you set. So yes, this option is already present in the software. I'm going to mark the feature as ADDED so that others know this has already been implemented in V5.
