alex_111
Movement Extrusion Override Settings are directly applied
Hi!
When I print and use the Override Boxes to enter a new value for Movement or Extrusion override, every value gets directly submitted.
So when i enter 100 (via keyboard) first 1 then 10 then 100 is send to the printer.
The bad thing is when the printer is on a long path and receives the 1% movement overide.
Better would be only to send out the command when changing focus and/or when hitting enter (better both)
DarthRevan
Re: Movement Extrusion Override Settings are directly applie
you won't run into this issue when using the dials or the up and down arrows.
AndersE
Interesting.. i have always used the dials, never manually.. good to know.
alex_111
DarthRevan wrote:you won't run into this issue when using the dials or the up and down arrows.
yeah but when setting back from 150% to 100 it's the most simple way to just enter 100?
you could click 50 times on the down arrow
or grab the well and try to dial in 100%,
where you get every setting from 95 to 105 within the process send to the printer.
