Drag and Drop
Posted: Fri Aug 18, 2023 7:09 am
by Monty3DP
Is there a reason why we still can't drag new models into S3D5?
This simple feature increases work flow and it's quite disrupting having to always click import and navigating to the folder. I assumed this will be added in the new 5.1.2 but still hasn't been added. A bit annoying and makes adapting to the new v5 a lot more cumbersome
Re: Drag and Drop
Posted: Fri Aug 18, 2023 10:03 am
by S3D-Jason
Works fine for me. Have been dragging and dropping models into V5 since the initial launch.
Just to check, if you close and re-open the software are you able to drag and drop models after that? If not, what exact OS are you using? Are you dropping models from a normal file on your local hard drive or some other odd location like Dropbox, Google Drive, or network shares?
