Solid layers rotation pattern help
Posted: Thu Aug 24, 2023 2:01 pm
This new software version looks like it got rid of the solid layers infill pattern rotation angles. Has this been taken out or has it been changed in a different menu location? please help
For example: I used to be able to have the solid infill rectilinear pattern switch direction every layer in any specific order. This helped close small holes left from the infill to the outline, without having to increase flow rate or outline overlap
layer 1: 0 degrees
layer 2: 90 degrees
layer 3: -45 degrees
layer 4: 45 degrees
layer 5: 0 degrees
layer6: 90 degrees
layer 6: -45 degrees
layer 8: 45 degrees
layer 1: 0 degrees
layer 2: 90 degrees
layer 4: 45 degrees
layer 5: 0 degrees
layer6: 90 degrees
layer 8: 45 degrees
