EVO1
Re: Multiple Issues with v5
This is 100% a SOPHOS issue and not S3D! I was fighting the exact same issues for weeks!
If you can`t manage the IT department, you might just check the setting "properties" in sophos!
You can select a box there to dissable sophos for 4 hours + deselect all functions.
This will fix the issues for at least 4 hours ;).
Attention: All your settings/changes in settings won´t be stored/saved in the profile or taken into the gcode when Sophos is active!
lemonade747
EVO1 wrote: Sat Apr 20, 2024 7:28 am This is 100% a SOPHOS issue and not S3D! I was fighting the exact same issues for weeks!
Thank you. It's confirmed that SOPHOS is the main issue and I'm arranging with my IT department to set up a special filter for me.
sbsimplify3d
Hello, I have the same problem here. Unfortunately, my IT is not able to set the appropriate exceptions. Is there a specific setting that needs to be made? Disabling Sophos in general is not an option.
Thank you in advance.
