Manually select replacement model
Posted: Sat Sep 02, 2023 4:26 am
There should be the option to manually select a replacement model file, as currently the live reload feature breaks as soon as you close the file. This should be an easy feature and big quality of life improvement, especially if you find you need to fix a model issue with a print with a lot of custom support work etc.
