this is a how-to request for Dremel 3D45
Posted: Sun Sep 17, 2023 1:24 pm
I am a brand new Simplify user with (at least) 2 questions.
I have defined several models/processes in order to change filament colors within a single project. The problem is that at the end of a process the machine comes to a full stop. Because of this the machine assumes a clean build plate (and therefore a new project) and does a 9 point check of the build plate. This of course causes crashes between the project and the extruder assembly.
The machine does allow a manual "Pause" during construction, thereby allowing a filament change, prior to proceeding.
Question 1. Is it possible to build in a pause "Pause" rather than "End" at the end of a process.
Question 2. I lieu of the above, is it possible to turn off that quality check at the beginning of each process?
Thank you in advance for your help.
