All,
Just installed S3DCreator 1.1.4. Generally I like the changes. But I had some trouble setting up custom macro buttons. Basically, the G-code in the macro button definition cannot contain comments. If it does, the G-code doesn't get sent. I think I'm setting it up right, with semicolons for the commend delimiter. I assume spaces before and/or after the semicolon are not a problem. I've attached a firmware file with my macro definitions.
What I'm trying to do is set up the three macro buttons to do the following on my MakerGear M2:
1st: Level Front: Position the extruder directly over the front leveling screw (X = 100 mm, Y = 75 mm)
2nd: Level Back: Position the extruder directly over the rear leveling screw (X = 100 mm, Y = 175 mm)
3rd: Level Right: Position the extruder directly over the right leveling screw (X = 150 mm, Y = 125 mm)
I'd really like to comment my G-code in the macro definitions. I like this for the "Level Right" button:
M104 S0 ; turn off extr heat
M140 S0 ; turn off bed heat
M106 S155 ; set fan to 12V
G90 ; absolute positioning
G1 F9000 ; Set fairly high speed
G1 Y125 ; Move Y first to avoid binder clips to center of axis
G1 X150 ; Move X so extruder is over right leveling screw
G1 Z0 ; Z back to home if not there
much better than this:
M104 S0
M140 S0
M106 S155
G90
G1 F9000
G1 Y125
G1 X150
G1 Z0
Dale
