[ADDED] Gcode pause function
Posted: Wed Sep 27, 2023 1:45 pm
by SgtJon
I have a Dremel 3d45. The Dremel people tell me that the firmware can support a "Pause" command. Could you
please make that available. Thank You
Re: Gcode function
Posted: Fri Sep 29, 2023 10:21 am
by S3D-Jason
S3D can already add gcode at specific layers or locations in the print. What exact gcode command did Dremel tell you to use?
Re: Gcode function
Posted: Fri Sep 29, 2023 12:33 pm
by SgtJon
I didn't ask. I simply asked if the firmware would support such a command and they replied "yes". I should mention that I am brand new to the S3D product and have no idea how I would specify the command other than selecting a specific option on the dashboard. What I'd like to see is the option presented the same way the start/stop option is displayed.
Re: Gcode function
Posted: Fri Sep 29, 2023 2:41 pm
by S3D-Jason
Ok, well ask them what exact command to use. Once you know that information, I bet we can help you add it correctly into S3D.
Re: Gcode function
Posted: Fri Oct 06, 2023 11:16 am
by SgtJon
Greg Herker at 3PI Tech tells me that his engineering folks are contacting Simplify directly. I'm hoping this can be done quickly because I really need this function.
Re: Gcode function
Posted: Fri Oct 06, 2023 3:28 pm
by TheBum
According to the RepRap G-code reference wiki (
https://reprap.org/wiki/G-code), M600 is supported by Marlin (the flavor of G-code Snapmaker uses). It's defined as a filament change pause, but I suppose you could use it for any purpose.
Re: Gcode function
Posted: Mon Oct 09, 2023 5:25 pm
by S3D-Jason
The OP asked about a Dremel printer, and I don't believe that uses the same command as the Snapmaker.
I believe the Dremel machine uses G5 to initiate a pause. So if you want to pause at layer 75, just add the following to Edit Process Settings > Scripts tab > Pre Layer Change Script:
{IF "[current_layer_number] == 75"}G5
That should pause the Dremel 3D45 at that layer.
Re: Gcode function
Posted: Wed Oct 11, 2023 10:34 am
by SgtJon
Jason thanks so much for your help.
