Extrusion Width - Recommendations?
Posted: Fri Mar 20, 2015 10:16 am
Assuming everything is calibrated perfectly and when I set the Extrusion Width to a value, THAT is what is actually printed...what are the reasons for going with one width over another? For example, my nozzle is 0.40mm, but the "auto" width is 0.48mm. A lot of people here suggest always going at least a little higher than the nozzle diameter, and I've been printing at around 0.45mm.
I guess what I'm not clear on is why I might want to go closer to 0.40 vs higher towards the 0.48 setting. Other than just having thicker walls for strength does it affect surface detail and quality? From what I understand S3D alters the space between your paths to accommodate the set width (assuming you have calibrated extrusion mult correctly) so their shouldn't be any gaps no matter what the width value. Is it also safe to guess that with smaller layer heights you want to avoid too high of a width value. Seems like I heard somewhere that 1.4/1.0 width/height ratio is ideal.
Any more info is appreciated.
Thanks,
M
Thanks,
M
