mixdup
Connect Infill Lines (Enable/Disable)
Can we please have a feature to enable or disable connection of the infill line ends where they meet the inner wall?
As per Cura feature:
Connect the ends where the infill pattern meets the inner wall using a line which follows the shape of the inner wall. Enabling this setting can make the infill adhere to the walls better and reduce the effects of infill on the quality of vertical surfaces. Disabling this setting reduces the amount of material used.
This is very important when printing single wall structures (3D printed aircraft) to maintain a consistent single wall. Currently the infill lines are connected so that an unwanted additional inner wall is created in an alternating pattern (depending on the infill pattern). The ability to turn this off would be very useful.
