Hello,
the Creality K1 has three fans. A side fan, a housing fan and a fan on the print head.
P0 = Print head fan
P1 = Housing fan
P2 = side fan
How can I select these fans in the setup? In the Simplify 3D fan settings I only see a cooling fan and a side fan. Is it possible to extend this list ? I would also like to be able to set the side fan.
Strangely, the side fan, which is actually much more important for printing, is switched off after printing with the command "M106 S0 P2 ", although it was not switched on before.
Best regards
