Temp Control For Dremel 3D45
Posted: Wed Nov 29, 2023 4:52 pm
by SgtJon
I just tried to adjust the Bed Temperature for the 3d45, but the machine is reporting a temperature 10 degrees
cooler than what I requested. Is this a software bug or am I doing something wrong?
Re: Temp Control For Dremel 3D45
Posted: Wed Dec 06, 2023 10:48 am
by S3D-Jason
We actually have several 3D45 machines here as well. I just tested a print on one of the machines using V5.1.2 and the bed temp heated to the correct value without issue. Can you try re-downloading the stock settings that we provide for the machine (Help > Configuration Assistant)?
Posted: Wed Dec 06, 2023 5:23 pm
by S3D-Taylor
Hi, can you use the touch screen interface of the printer, go to Tools->Setting->Adv. Mode->Turn ON "Prioritize G-code settings". If this settings was OFF, the default material properties will override the setting set by Simplify3D. Please let me know if it works for you.
