Copy a process from one Factory File to another?
Posted: Tue Dec 05, 2023 9:54 am
by Joymaker
I wish I could copy and paste an entire process with all its settings from one factory file to another. Why? Because I have two finally tuned processes in two different files, and now I would like to run them sequentially as part of one print. Is there any way? Or do I just have to manually copy all of those settings?
Re: Copy a process from one Factory File to another?
Posted: Tue Dec 05, 2023 12:25 pm
by Instrumentation
I think you can export your process as a printer profile, and then import it into your other factory file, but then you'll always have two separate profiles holding your configuration settings.
I don't think there's an easy way to automatically pull the configuration into another profile, but the option to highlight different cells could be handy. It will only compare to whatever auto-configure was saved last, so it's not foolproof.
Posted: Wed Dec 06, 2023 10:32 am
by S3D-Jason
Agree with the comment above. There's no way to export a process by yourself, but you can achieve the same thing by double-clicking on the process, choose Save As New to save those settings as a new profile. At that point you can open the other factory file, double-click on a process, and then use the "Select Profile" drop down list to load the new settings.
