Creality K1 wifi connection
Posted: Thu Dec 14, 2023 11:11 am
by msmola
When is "supported" Creality K1 (and support via wifi in S3D does not work), could be somewhere in "Begin printing on machine" for this printer used web interface, where is possible import and print created gcode ?
Creality using for it easy:
http://IP/#/home
Re: Creality K1 wifi connection
Posted: Fri Dec 15, 2023 9:55 am
by S3D-Jason
S3D already supports wifi connection to Klipper based printers. Creality uses a very similar Klipper firmware on their K1 machine, but they actually modified the wifi communication enough so that it won't connect with any standard tools. It looks like extra software changes will be required before it will be compatible. I have already shared this with our development team so that they can investigate the change for the future.
Posted: Wed Dec 20, 2023 2:50 am
by msmola
Will that take several years? Couldn't you use your brain and add an option for K1/K1 Max to call their web interface from S3D and import G-code through it to start printing?
Call it wit: http://K1_IP/#/home
Posted: Fri Dec 22, 2023 12:46 pm
by S3D-Jason
That URL just opens the web interface that runs on the printer itself, but S3D would still need code to navigate that interface, attach the files, submit, and start the print. There's quite a bit more than just opening the page to make it work well with all features in the software.
I know our team is looking into it, so hopefully they will have a solution soon!
Posted: Wed Jan 31, 2024 9:35 am
by Michael_Jakob
Root your printer and install FLUIDD. This will allow you the connect with the printer IP and port 4408. More detail can be found here:
https://github.com/Guilouz/Creality-K1- ... per-Script
