solidlayers when infill is 100%
Posted: Mon Dec 18, 2023 10:04 am
by nophead
When I slice this object that has holes in the bottom it creates 4 layers of infill to cover them. This makes sense when the infill is sparse but I am using 100% infill so it should just be one single layer of 100% fill.
Re: solidlayers when infill is 100%
Posted: Mon Dec 18, 2023 10:48 am
by S3D-Jason
The internal infill and the outer solid layers can each have very different settings. You might be using different speeds, extrusion rates, widths, etc. That is why they are typically printed separately. For example, I bet if you change the preview coloring to movement speed, you will see those 2 regions use a different printing speed.
If you want to just print everything together with 100% infill, an easy trick is to go to Edit Process Settings > Infill tab, and enable the "Add Solid Diaphragms" option with 1 layer and 0 spacing. Now the entire part will be a single solid region.
Posted: Mon Dec 18, 2023 11:20 am
by nophead
They are all the same speed because I try to print at constant flow rate for best quality.
The Add Solid Diaphragms trick works though, thanks.
Posted: Thu Jan 04, 2024 10:41 pm
by gearsawe
so when I print 100% infill I set top and bottom layers to zero.
