[SOLVED] Extrusion multiplier affects slicing? Calibration cube problems.
Posted: Sat Dec 30, 2023 11:01 am
I am trying to calibrate the relationship between my printer's extruder and different spools of filament.
I created multi-setting profile groups to test the extrusion at 0.80, 0.85, 0.90, 0.95, 1.00, and 1.05 extrusion multipliers.
What I was expecting was for every cube to be printed in exactly the same way, just with a different extrusion distance in the output gcode.
Instead, I found that the cubes had very strange outputs:
https://imgur.com/uGBDgkv
All cubes except the cube with the multiplier set to 1.00 had most of their perimeters missing except on one face.
The cube with the multiplier set to 1.00 had inside perimeters missing.
This doesn't seem right, but I can't seem figure out if I am missing some detail. The cubes should print as identical cubes, right (except the extrusion distance)?
