Simplify3D and Original Prusa XL
Posted: Sat Dec 30, 2023 4:31 pm
Has anyone been successful with Simplify3D and the Original Prusa XL multitool?
S3D provided a profile (from an unknown source/user). I gave it a try and 3/4 through the print the Nextruder suddenly dropped into the print and drug it to the side breaking the print into 2 pieces. The print stayed adhered to the bed on the bottom section. There was a substantial 'divot' in the top layers of the upper, broken part. I experienced this type of event using a prior printer (QIDI X-Max) where the supplied profile had erroneous Z build dimensions and at the end of the print, instead of lowering the print bed, it raised it causing the hot end assembly to punch into the model.
I checked the S3D profile (for the Prusa XL) and the build dimensions are set properly. Since it occurred mid-print I'm thinking there must be a different cause.
Before I went back to Prusa Slicer I did a full printer factory reset, reflashed the firmware, full reset again and did a full re-calibrate. No issues at all with PrusaSlicer.
