hi there
i wann use pla as partmaterial and petg as supportmaterial (only for the denselayer) on my idex printer.
some firt attemp ware very promising, and i'm almost there!
on the left extruder (T0) i use the pla and on the right exteruder (T1) is use petg material.
almost everything works, but two problems to solve are left:
1. when the extruder (T0) is finnish with the job, he do not move out of the part immediately. he make a short break ( 1-3 second ) in the
part which gives me a ring of material which cause problem.
2. before the next extruder (T1) starts, he should make a purge a def. amount of material befor he starts to work.
3. step 1 & 2 should should repeat on every tool change!
in s3d v5.0 there are two scripts for tool change.
pre toolchange script:
{IF NEWTOOL=0}M106 S[fan0_speed_pwm] T0
{IF NEWTOOL=0}M106 S0 T1
{IF NEWTOOL=1}M106 S[fan1_speed_pwm] T1
{IF NEWTOOL=1}M106 S0 T0
post toolchange script:
(empty)
can someone help me to finish the scripts with point 1. & 2?
thanks,
andy
