Tool Change Script ( Craftbot Idex Flow ) S3D V5.0
Posted: Mon Jan 15, 2024 7:10 pm
by multicopter
hi there
i wann use pla as partmaterial and petg as supportmaterial (only for the denselayer) on my idex printer.
some firt attemp ware very promising, and i'm almost there!
on the left extruder (T0) i use the pla and on the right exteruder (T1) is use petg material.
almost everything works, but two problems to solve are left:
1. when the extruder (T0) is finnish with the job, he do not move out of the part immediately. he make a short break ( 1-3 second ) in the
part which gives me a ring of material which cause problem.
2. before the next extruder (T1) starts, he should make a purge a def. amount of material befor he starts to work.
3. step 1 & 2 should should repeat on every tool change!
in s3d v5.0 there are two scripts for tool change.
pre toolchange script:
{IF NEWTOOL=0}M106 S[fan0_speed_pwm] T0
{IF NEWTOOL=0}M106 S0 T1
{IF NEWTOOL=1}M106 S[fan1_speed_pwm] T1
{IF NEWTOOL=1}M106 S0 T0
post toolchange script:
(empty)
can someone help me to finish the scripts with point 1. & 2?
thanks,
andy
Re: Tool Change Script ( Craftbot Idex Flow ) S3D V5.0
Posted: Tue Jan 16, 2024 9:30 am
by S3D-Jason
Typically, the "short break" you mentioned after changing tools is actually when a tool change retraction is taking place. The nozzle will be stationary during that time while the filament is retracting, so it may look like it is paused.
If you want to change how much material is retracted or primed after each tool change, you can find those settings at Edit Process Settings > Other tab > Tool Change Retraction settings.
Posted: Mon Jan 22, 2024 7:31 am
by multicopter
@s3d-jason
thanks i wil try it out. any suggestion about the tool change script?
thanks,
andy
Posted: Mon Jan 22, 2024 9:03 am
by S3D-Jason
If you're just learning gcode for the first time, I would highly recommend this article:
https://www.simplify3d.com/resources/ar ... -tutorial/
It explains common commands for moving, purging, preheating, etc. Once you understand the commands, it's much easier to write your own scripts.
Posted: Fri Feb 28, 2025 3:53 am
by multicopter
Thanks to ChatGPT, I managed to create a tool change script that purges the nozzles after the tool change.
It took me less than 5 minutes!!!!
This must be set as the Post Tool Change Script:
; Post Tool Change Script - Purge after Tool Change
G92 E0 ; Reset extruder position
G1 E70 F600 ; Extrude 70 mm of filament for purging
G92 E0 ; Reset extruder position again
