Support pattern rotation and random crashing bugs
Posted: Fri Jan 26, 2024 5:29 pm
by blj1884
Support Pattern Rotation does not allow you to specify and makes it existence irrelevant. So it doesn't help.
Also, I would really appreciate it if your team would "FIX" the random crashing and locking up that happened when adjusting the Layer Range to Show feature after slicing. Also Simplify3D for some reason puts artifacts in the sliced file. Like layer gaps in an areas. It is similar to v4 where you change one setting and it breaks the profile so you have to nuke it and start over.  Once these issues happen, you have no choice but to delete everything and start over?
You guys need to "FIX" these bugs! This pattern is starting to make me think Simplify3D is not long for this world. That would suck.
How about a crash report so we can give it to you with an explanation of the issue we see? You know, like mostprograms have. It is starting to feel like version 5 was one last paycheck.
Re: Support pattern rotation and random crashing bugs
Posted: Mon Jan 29, 2024 3:09 pm
by S3D-Jason
Can you provide links to the posts where you already reported these issues? For example, I wasn't able to find the one about support pattern rotation after reading through your posts.
I do see that you reported a crashing issue in the past, but I have to say that I use V5.1.2 constantly every day and I haven't experienced the constant crashing when adjusting the layer slider. Is it possible it is related to a specific model or profile you are using? If the crash is repeatable, can you attach a factory file that would reproduce the issue?
