eldonz
STL is not printing correctly
Hello,
The print object looks just fine on the preview and shows no errors. When I "Prepare to Print", the object prints as a solid and does not leave the cutouts in the middle.
Suggestions?
Thanks,
Eldon
HDNS-2100_#001_Base_Plate.factory
(7.14 KiB) Downloaded 192 times
S3D-Taylor
Re: STL is not printing correctly
You have 'Merge All Boundaries' selected for the Slicing Region Repair Mode (Advanced tab-> Slicing Behavior). Simply change that to Alternating Fill or Positive Fill and the problem should be resolved.
You can read more about it here: https://www.simplify3d.com/resources/ar ... sh-errors/
eldonz
Thank you for responding and getting me pointed in the right direction.
Later,
Eldon
