WF55 wrote: ↑Sat Feb 03, 2024 1:09 pm
Often this is a mechanical problem. You have to correct this in the printer's firmware.
How exactly would you "correct" a mechanical problem in firmware? Before using less than ideal
workarounds like skew correction I'd recommended fixing the problem. Not trying to mask it.
Unfortunately, Simplify3D only has the option of compensating for a length error for the X-axis and the Y-axis at the same time (horizontal Outer Size compensation).
That's absolutely NOT what horizontal size compensation is about, it's not meant to compensate for an axis that doesn't move
as expected.
exxosuk wrote:
I am printing a circle and it's supposed to be 80.5mm on box XY axis.
Did you actually check the model? STL files do not contain arcs/circles. And depending on the export settings of the design
software this might be more or less detailed. This also effects dimensional accuracy, so it'd be important to know what you
did and how you took measure.
Also there's many people with sloppy retracts, taking measurements in the area where material flow is still increasing when
printing the perimeter.
exxosuk wrote:
I have calibrated the Axis the printer multiple times and the print is always out anyway.
Did you check if the y/x axis do move properly on your printer, maybe by simply using calipers/a dial gauge and using the
menu on the printer itself, ruling out any software/slicing problem?
If that's correct - what's the output of the slicer, are coordinates like they should be within the gcode, is the distance
between min/max x of the circle you're printing the same as min/max y? (Keep segmentation of STL files in mind)
Do you see any problems when printing objects with less segments, like a rectangle or hexagon? Is the offset along Y
always 0.5mm short or is it a percentage off when scaling objects?
