BRELETRONICA
Problem installing Simplify V5 windows 10
I had the V4 version of simplify which worked perfectly and still works.
However, when upgrading to version V5, you don't even want to open the software, presenting several errors.
Attached is the image
*** I have already installed it on two different machines and the problem persists.
Captura de tela 2024-02-02 191956.png (8.22 KiB) Viewed 991 times
Re: Problem installing Simplify V5 windows 10
That error message is actually coming from Windows, not Simplify3D. Have you made sure to install all available Windows updates for the computer? That can sometimes be the cause for errors like that.
There's also a few suggestions at the link below that might help:
https://www.techadvisor.com/article/727 ... 0007b.html
