[SOLVED] I can't add my "Creality K1 AI Max" to Simplify3D
Posted: Tue Feb 06, 2024 12:39 pm
Hello to the forum!
Yesterday I got my new "Creality K1 AI Max" and of course I want to use it with Simplify3D 5.1.2.
However, I have the following problem:
I have added the profile of the "Creality K1 AI Max" via the configuration wizard.
I then wanted to add the printer via the machine control panel and first selected the printer there, selected "Network connection (Ethernet, WiFi)" as the connection method and tried both options ("Search for connections" and "Manual connection details"):
"Search for connections" option:
"Search for devices" does not work and the printer is not found. This is strange, because when I use the "Creality Print" software, the printer is found immediately. I therefore assume that Simplify3D should also be able to find the printer...
Option "Manual connection details":
Here I fail to specify the port, because neither ports 80, 8080, 4408 or 4409 work. This is despite the fact that I can access the printer with the "Creality Print" software. I can also access the web interface via the browser using port 4408 (I rooted the printer straight away).
Can anyone tell me how I can add the printer to Simplify3D?
Greetings from a stormy Dresden
"Klaus"
"Klaus"
