How to do parts with different infill?
Posted: Wed Feb 07, 2024 10:41 am
by kent999
example.. i will do everything with infill, but not "hat brown" - how i do? If this is possible..?!
kent
kent
Re: How to do parts with different infill?
Posted: Wed Feb 07, 2024 12:54 pm
by S3D-Jason
Go to Tools > Variable Settings Wizard, and choose "Different settings for different models". You can then choose how many groups you need (in your case, 2 groups should be fine - one with infill and one without infill). Then drag the models into the correct groupings.
After you complete the wizard, you will have 2 processes that control the settings in each group. Double click on either process to change the settings for those models. You can then verify everything in the preview to make sure it is correct.
Posted: Wed Feb 07, 2024 5:12 pm
by kent999
S3D-Jason wrote: ↑Wed Feb 07, 2024 12:54 pm Go to Tools > Variable Settings Wizard, and choose "Different settings for different models". You can then choose how many groups you need (in your case, 2 groups should be fine - one with infill and one without infill). Then drag the models into the correct groupings.
Ahhh.. smart thanks again Jason for your help :)
Posted: Mon Mar 04, 2024 10:06 am
by S3D-Jason
Happy to help!
