kmleatherwood
Tall print with layer problems in small section
When I print a taller print in Vase/spiral mode, I get random small areas of inconsistent layers. Most of the print is perfect but random layer issues come up.
Fans at 100% throughout print
Material: CPX (polypropylene blend)
3mm nozzle
2mm layer height
5mm layer width
Re: Tall print with layer problems in small section
Can you post the factory file for the print? In the one photo, it almost looks like it could be cooling related where the plastic is overheating.
