Supports wraping up
Posted: Sun Mar 22, 2015 2:27 pm
by Linas_capas
Hello everyone. I have just upgraded to simplify3d, but I am facing major issue. On first layer, when i print "zigzag" support, when direction change happens, my filament seems to wrap up in that corner. So i get a zigzag with for example right corners wraped. I have tried to lower the nozzle as much as possible, still the same thing. Any ideas? Thanks
Re: Supports wraping up
Posted: Mon Mar 23, 2015 6:56 am
by JoeJ
You could try lower the speed at which the support structures are printed. Click "edit process settings", select Other tab, and lower the Support Structure Underspeed setting.
Posted: Mon Mar 23, 2015 4:49 pm
by Linas_capas
JoeJ wrote:You could try lower the speed at which the support structures are printed. Click "edit process settings", select Other tab, and lower the Support Structure Underspeed setting.
I tried doing that, still same thing. Here are few photos:
Posted: Mon Mar 23, 2015 8:24 pm
by KC_703
Is there a pattern to which corner warps up?
Here are some ideas:
- Try re-leveling the bed... maybe one side is lower than the other resulting in poor adhesion
- Increase the first layer extrusion temp. Given you have good adhesion, a higher temp will help the filament stay molten and lay on the bed
- Figure out how to get better adhesion. With ABS this could be an ABS slurry, with PLA it could be hairspray or gluestick...
