Do your Factory files pull in saved Profiles?
Posted: Sat Apr 06, 2024 12:47 pm
I am having a problem with saved "Profiles" being pulled into different "Factory" files. If I save a Factory file that has a Process that uses specific Profile, then I modify that profile and save it, when I open another Factory file that uses the same Profile the saved changes aren't retained and revert back to the prior state. For example, I have been working on a calibration file and updating process(es) and when I go to use them in the Factory file I want to have pull in the updated process(es) they are back to the same as they were before. I am nearly certain Simplify3D did not function like this before. Has anyone else experienced this problem? If so, any suggestions on how I can go about fixing it?
Thanks,
Sean
Thanks,
Sean
