[SOLVED] adaptive mesh leveling (bed mesh on print area only)
Posted: Sat Apr 20, 2024 12:04 pm
by Lc1975
Hello...
does the new version of simplify3d has the Adaptive Mesh Leveling ?
prusaslicer, orcaslicer has this command for that.
something like this:
https://www.youtube.com/watch?v=ag6nWA3_scQ
(prusaslicer, orcaslicer has this command for that.)
Re: adaptive mesh leveling (bed mesh on print area only)
Posted: Mon Apr 22, 2024 9:39 am
by S3D-Jason
Yes, this is fairly easy to do using the [build_min_*] and [build_max_*] variables. Just add the following to your starting script depending on which firmware you are using:
Klipper:
BED_MESH_CALIBRATE mesh_min=[build_min_x],[build_min_y] mesh_max=[build_max_x],[build_max_y] PROBE_COUNT=6,6
Marlin:
G29 L[build_min_x] R[build_max_x] F[build_min_y] B[build_max_y]
Posted: Mon Apr 22, 2024 5:08 pm
by Lc1975
i use reprap (duet board)
thank you for your reply.
help me a lot.
i only change the letters L=A, R=B, F=C, B=D
Re: [SOLVED] adaptive mesh leveling (bed mesh on print area only)
Posted: Sun May 05, 2024 10:33 am
by pcganns
Hey,
Unfortunately it does not work properly on the K1 Max. The printer goes into a loop to mount the adaptive bedmesh and does not start printing.
Posted: Tue May 07, 2024 11:04 am
by S3D-Jason
The K1 made a lot of changes to the regular Klipper firmware, so it's possible they might require some kind of different changes. I would recommend opening a topic in the troubleshooting sub-forum and posting more details about the behavior.
Posted: Mon May 13, 2024 4:22 pm
by Lc1975
i tested the same part in the same position
slicer (orca) and there is a difference in calculating the area for mesh leveling...
simplify3d:
M98 P"print_a_mesh.g" A96.09 B203.91 C89.54 D182.46
orcaslicer:
M98 P"print_a_mesh.g" A135.46 B177.318 C97.5004 D184.327
orca is more accurate...
simplify3d enlarge way more the area compared with orca...
Posted: Tue May 14, 2024 9:36 am
by S3D-Jason
It doesn't enlarge the area at all unless you have Additions turned on like a skirt, raft, ooze shield, etc. Those will all increase the area since they are added beside the part.
Posted: Fri May 17, 2024 1:00 pm
by Lc1975
Yes it's like you said.
simplify3d calculates with addition turned on, while orcaslicer does not.
Posted: Tue May 21, 2024 9:19 am
by S3D-Jason
Yes, that's the intentional behavior. If you don't include the additions then things like the prime pillar or ooze shield might fail to stick to the bed. That can easily ruin the printer, so we include it in the overall build dimensions.
