Connecting An Unknown Printer - How?
Posted: Mon Apr 22, 2024 10:24 am
I have been trying to connect a printer to S3D - the printer does not have a match for published and supported devices.
The failure I am experiencing isn’t related to quality settings, which I am genuinely comfortable with, it’s the physical connection of an unknown printer that is the issue.
For known printers there is no issue - just select the printer from the dropdown in the configuration assistant which produces the initial profile. Everything is sweet and rosy from there on.
However with an unknown printer S3D falls over when you try to print using an unmatched profile - S3D gets an ID from the printer which doesn’t match the profile.
What is the key to success here? How do I create a profile for an unknown printer? Is there a youtube video which explains this?
