joachim_ch
Export printer profile
Hi, finally I upgraded to 5.1.2 - and trying different Linux Distributions. I have 4 printers and with different nozzles and filament more than 20 printer profiles. Exporting these like in the stoneage one by one is a real pain in the a... :shock:
2024 - I expect a funktion "Export ALL profiles". Why can I import them all together but not export them so.
Joachim
Re: Export printer profile
If you go to the folder listed in this link:
https://www.simplify3d.com/resources/faq/#quest-6350
You can open the Profiles folder and you can already see all the XML profiles loaded in to the software. You can then copy those to the other computer, go to File > Import Profiles, and make sure .xml is selected in the drop down, then select all of the files to load them all at once.
