Grzyby15
Re: Tip of the Day Compilation: FFF Settings Window
Mon May 25, 2015 5:18 am
Nice forum, greets to everybody:)
bionicrocky
Tue Aug 18, 2015 4:37 am
This is so RAD! Printing up to sit next to the printer!
jakejakezack
Tue Aug 18, 2015 10:03 pm
:o The Links do not seem to work??
bananaman
Wed Aug 19, 2015 6:09 am
Great tips, really helped me get an understanding, BUT now I get an forum error trying to access them. Just me? Really should have printed them out.
bananaman
Wed Aug 19, 2015 5:30 pm
It is working again!, printer is warming up.
AIBLTD
Thu Nov 12, 2015 3:57 am
Thanks so much!
Balu
Mon May 02, 2016 6:24 am
With all these settings we have, does anyone have a list of what setting depends on what "profile type"?
Like what is changed when switching the printer profile, the filament profile or quality setting?
wfcook
Tue May 03, 2016 12:03 pm
Balu wrote:With all these settings we have, does anyone have a list of what setting depends on what "profile type"?
This would be very handy.
KC_703
Wed May 04, 2016 12:54 am
One of the S3D videos list the parameter which the "Material" and Quality" profiles store. Here's their video.
I use the "Material" profile to store paramters in the: Extruder, Temperature and Cooling tabs.
Sample from a dual extruder Material autoconfigure profile:
  <autoConfigureMaterial name="ABS-LH3-Black">
    <extruder name="Back Extruder">
      <toolheadNumber>0</toolheadNumber>
      <diameter>0.5</diameter>
      <autoWidth>1</autoWidth>
      <width>0.6</width>
      <extrusionMultiplier>0.94</extrusionMultiplier>
      <useRetract>1</useRetract>
      <retractionDistance>0.9</retractionDistance>
      <extraRestartDistance>0</extraRestartDistance>
      <retractionZLift>0</retractionZLift>
      <retractionSpeed>1800</retractionSpeed>
      <useCoasting>1</useCoasting>
      <coastingDistance>0.2</coastingDistance>
      <useWipe>0</useWipe>
      <wipeDistance>5</wipeDistance>
    </extruder>
    <extruder name="Front Extruder">
      <toolheadNumber>1</toolheadNumber>
      <width>0.6</width>
    </extruder>
    <temperatureController name="Back Extruder Temperature">
      <temperatureNumber>0</temperatureNumber>
      <isHeatedBed>0</isHeatedBed>
      <relayBetweenLayers>0</relayBetweenLayers>
      <relayBetweenLoops>0</relayBetweenLoops>
      <stabilizeAtStartup>1</stabilizeAtStartup>
      <setpoint layer="1" temperature="245"/>
      <setpoint layer="10" temperature="243"/>
      <setpoint layer="33" temperature="243"/>
    </temperatureController>
    <temperatureController name="Front Extruder Temperature">
      <temperatureNumber>1</temperatureNumber>
    <temperatureController name="Heated Bed">
      <temperatureNumber>2</temperatureNumber>
      <isHeatedBed>1</isHeatedBed>
      <stabilizeAtStartup>0</stabilizeAtStartup>
      <setpoint layer="1" temperature="110"/>
      <setpoint layer="2" temperature="110"/>
      <setpoint layer="10" temperature="100"/>
      <setpoint layer="60" temperature="90"/>
    <fanSpeed>
      <setpoint layer="1" speed="0"/>
      <setpoint layer="2" speed="60"/>
      <setpoint layer="4" speed="0"/>
      <setpoint layer="10" speed="50"/>
    </fanSpeed>
  </autoConfigureMaterial>
"Quality" stores the parameters for other tabs. I use these profiles to store Layer and Speed (OTHERS tab) parameters, but I've added Z-offset (GCODE tab) and filament diameter as a test.
Sample:
  <autoConfigureQuality name="LH3_5400">
    <globalExtrusionMultiplier>0.94</globalExtrusionMultiplier>
    <layerHeight>0.3</layerHeight>
    <topSolidLayers>4</topSolidLayers>
    <bottomSolidLayers>4</bottomSolidLayers>
    <skirtLayers>1</skirtLayers>
    <skirtOutlines>3</skirtOutlines>
    <infillPercentage>100</infillPercentage>
    <supportInfillPercentage>20</supportInfillPercentage>
    <defaultSpeed>5400</defaultSpeed>
    <outlineUnderspeed>0.4</outlineUnderspeed>
    <solidInfillUnderspeed>0.8</solidInfillUnderspeed>
    <supportUnderspeed>1.1</supportUnderspeed>
    <rapidXYspeed>6000</rapidXYspeed>
    <gcodeZoffset>.1</gcodeZoffset>
    <filamentDiameter>3</filamentDiameter>
  </autoConfigureQuality>
Note the Multiplier (from the Extruder tab governed by Material) can be modified by adding the "global". Its probably just scratching the surface,
Attached an old FFF for a single extruder which has multiple "Material" and "Quality" autoconfigure profiles. FFFs are best viewed and manipulated in an XML editor like Notepad++ (Windows) or TextWrangler (Mac).
Hope this helps.
TAZ5-N5_20151219_01.txt
Change the .txt to .fff to import.
(45.06 KiB) Downloaded 476 times
