skunkworx
Creality K1 Max
the installed k1 max profile when print has finished does not lower the bed.
what gcode to i need to add the end script to lower the bed when print is complete
regards
Re: Creality K1 Max
You can usually lower the bed by just moving to a specific Z position at the end of the print.
For example, if you printer Z height was 200mm, you could just add this in your ending script
G1 Z200 F1800 ; move to Z=200 at 1800mm/min
