Evaluating Simplify3D Material Profiles
Posted: Tue Aug 06, 2024 11:14 pm
by HowardFisher
I've been exploring the different material profiles built into Simplify3D, and I'm curious to learn more about how these profiles are configured under the hood.
Do I need a flowchart to access the detailed settings behind each material profile? For example, where can I see the specific parameter values ​​that Simplify3D is adjusting when I select a different filament type?
Also, are there any best practices for customizing these material profiles to further optimize the settings for your own 3D printing needs? I'm particularly interested in understanding how to adjust support settings, infill patterns, and other advanced parameters for different filament types.
Re: Evaluating Simplify3D Material Profiles
Posted: Wed Dec 04, 2024 9:04 pm
by snailsadmire
HowardFisher wrote: ↑Tue Aug 06, 2024 11:14 pm I've been exploring the different material profiles built into Simplify3D, and I'm curious to learn more about how these profiles are configured under the hood.
Also, are there any best practices for customizing these material profiles to further optimize the settings for your own 3D printing needs? I'm particularly interested in understanding how to adjust support settings, infill patterns, and other advanced parameters for different filament types.snow rider
Accessing Material Profiles
Edit Process Settings:
Open Edit Process Settings to see and modify parameters like temperature, cooling, and extrusion for the selected filament.
Profile Manager:
Use it to view, duplicate, or edit profiles. Export/import profiles as needed.
Customizing Profiles
Start with Defaults:
Use built-in profiles as a baseline and tweak based on filament specs.
Adjust Key Settings:
Supports: Modify overhang angle and spacing for minimal material use.
Infill: Test patterns like honeycomb or grid for strength vs. weight.
Retraction: Fine-tune to prevent stringing for tricky materials.
Advanced Features:
Adjust Coasting or Wipe Distance to reduce oozing and marks.
Test and Save:
Use test prints (e.g., temperature towers) and save customized profiles.
Tips
Use the Profile Manager for comparisons.
Check online for community-shared profiles.
Refer to filament specs for optimal starting points.
