Various improvements for variable settings wizard
Posted: Thu Aug 15, 2024 3:54 pm
I have an improvement for each method of varying settings. For the first method "Different Settings for Different Models" when all models are broken out into their own process there should be a check box to append the name of the model that the process prints to the process name. This would make the process titles much clearer when doing batch printing object by object. For example when printing the models benchy, cali cat, and xyz calibration cube with the base process title of NAT ABS 1.0mm the process window would go from:
NAT ABS 1.0mm (Set 1)
NAT ABS 1.0mm (Set 2)
NAT ABS 1.0mm (Set 3)
to:
NAT ABS 1.0mm (benchy)
NAT ABS 1.0mm (cali cat)
NAT ABS 1.0mm (xyz calibration cube)
For the second method in variable settings wizard "Different Settings for Different Z-Ranges" the Z-axis positions input box should be made to accept CSV data for height ranges. For example when separating the height ranges of a process at 10mm, 50mm, 80mm, and 350mm, rather than individually typing each number and hitting add after every input you would just type "10,50,80,350" and hit add once.
to:
