Hello, I am printing using the Makerbot Desktop, but want to feed it .makerbot files from Simplify3D to have more control. My first problem is that the z-offset needs to be set. in Makerbot Desktop I've got the z-offset set to -0,20mm and that seems to work great for printing from there.
In Simplify3D, I've attempted to set the same z-offset under the "G-Code" tab, in the "G-Code offsets" values, changing the Z-Axis to "-0,20mm" and even trying higher values (-0,40mm) but nothing seems to work - when I print the sliced file using Makerbot Desktop the first layer is still dropped in the air.
Am I changing the wrong number, or in the wrong place?
