saeed
Sequental Printing(p-by-p) not working with multi process per obj
Hi
this article has coverd 3 printing method:
- Single Process Printing Mode
-Multiple Process, Continuous Printing Mode
-Multiple Process, Sequential Printing Mode
but we have this situation :
-Multiple Process per each cloned obj in Sequential Printing Mode
if we have ONLY ONE process per obj then Sequential Printing Mode with max clearance height work fine but we have :
many clone( to-fill-printing-bed) of an object with many process per height zone
then gcode not working as process by process and it work layer by layer
could you fix this?
my previous long time ago topic still not fixed , may i ask for a minor update ? long time no see dev team :)
S3D-Taylor
Re: Sequental Printing(p-by-p) not working with multi process per obj
I just tested it on my end and sequential printing when multiple processes are assigned to an object works as intended. Could you attach a factory file here to show if that isn't the case? Also, what values are you using for the Max Clearance height?
