Cooling tab
Posted: Wed Dec 11, 2024 9:35 pm
by billyd
Auto cooling for layers below set time not calculating layer times accurately.
Re: Cooling tab
Posted: Thu Dec 12, 2024 9:48 am
by S3D-Jason
It seemed to be working from my tests. Can you post more specific details? It might help to include a factory file and show the exact lines in the gcode file you think are wrong, and what you expected them to be.
Re: Cooling tab
Posted: Thu Dec 12, 2024 10:56 am
by billyd
In the attached factory files, the one with a single pair never turns on the cooling fan and the layers are very fast, maybe 3 to 5 seconds each, and ironically, the factory file with four pairs of parts puts the cooling fan on 50% (after the first 10 layers are complete) and the layers are still well above 20 seconds each.
Re: Cooling tab
Posted: Thu Dec 12, 2024 11:03 am
by billyd
I think the reason the fan never comes on for the single pair, is because the m106 command is inserted prior to the call to the start_print macro in my scripts. I think S3D should place an initial call to the cooling fan (for auto cooling) after all initial user starting scripts, not before.
Re: Cooling tab
Posted: Fri Dec 13, 2024 12:51 pm
by S3D-Jason
Typically, if you want to set the fan speed manually in the starting script or control exactly where that command is placed, then you would use the [fan_speed_pwm] placeholder variable. That stops the software from adding its own commands afterwards.
