V5.1.2 Crashes with Dremel 3D20
Posted: Fri Dec 13, 2024 11:32 am
I've submitted this thru the Contacts link on Simply support page and posting here to see if anyone else has seen this.
RonI am running your V5.1.2 product on Mac OS v12.7.6 using my Dremel 3D20 (see Verifying connection.txt). The first time the printer is added and I connect with the printer while it is doing nothing I get timeouts for the commands which are repeatedly sent for print status, temp, and endstop states (see Connection Made No Print Attempted.txt).
If I try to do anything at this point your S3D SW crashes. For example, Disconnecting. I see on the comms window the M602 cmd go out but the SW crashes (sorry no log for that). Same is true if I try Begin Printing on Machine in the preview mode, or I try Play from the machine control window (with a set of files that print if I use the ext SD card).
I can print if I do the following:
0) No printer connect to Mac, no printer added in S3D. S3D opened.
1) add printer using your Dremel 3D20 profile (this where I get verifying connection.txt log). Printer is added and disconnected.
2) from preview mode use Begin Printing on Machine (see Mini Print.txt).
3) print runs to completion, but notice at the end of the mini print file, the timeouts occur once the printer is homed and idle.
