Question about extrusion widht calibration
Posted: Tue Mar 31, 2015 6:44 am
by MikaMa
I made profiles for 0.1mm, 0.2mm and 0.3mm layer resolutions and am manually calibrating them for optimal output. I managed to calibrate 0.3mm already with the following settings:
Nozzle diameter: 0.4
Extrusion multiplier: 0,92
Extrusion widht: 0,42
calibration went pretty close and the perimeter was smooth.
Now I am trying to calibrate 0.2mm but have some problems with the surfaces. I have now measured that with these calculations the result should be ok:
Extrusion multiplier: 0,85
Extrusion widht: 0,28
But the result is this:
One of the walls has tiny holes. The surface is otherwise perfect and smooth. I closely watched the printing and noticed when they were formed. Everytime I heard a "zap" sound and the hole appeared. SO my question is:
1) are the holes caused by moisture in the filament
2) Should I increase extrusion multiplier?
3) Should I increase extrusion width? (which is mathematically correct)
4) all of the above or something else?
any ideas :)
Re: Question about extrusion widht calibration
Posted: Tue Mar 31, 2015 9:13 am
by dennisjm
Leave extrusion width at .42. When you put it to .28 only 1/2 the plastic is going to be extruded. It will also make the toolpath 1/2 the distance apart but really it's difficult to get good results not pushing enough plastic through the extruder.
For my profiles, I don't need to adjust extrusion multiplier and nozzle width when changing layer height. The software compensates for the amount of plastic you need for varying layer heights.
Posted: Tue Mar 31, 2015 11:28 am
by MikaMa
I tried 0.42 but still gives me small holes.
Posted: Tue Mar 31, 2015 1:49 pm
by MikaMa
The problem persist it seems.
I printed a cube with the following settings.
Top solid 0
Bottom solid 2
Shells 1
The print went otherwise good (wall thickness average 0.42, smooth 3 walls) but one wall still had few holes.
how to get rid of them?? Any tips
