Bugs in Cooldown extruder while idle
Posted: Fri Mar 07, 2025 5:31 pm
There are bugs that are encountered when using Cooldown extruder while idle when attempting to print with 2 extruders.
At startup, Simplify3D will ignore the cooldown settings. Simplify 3D turns on both extruders at full power. It should only turn on the active extruder at full power, and cooldown the other extruder.
You will see this at the start in the G-Code (cooldown is set to 170 C in my test, but we see 220 C here):
When Stabilize temperature controller at beginning of print is enabled, Simplify3D will ignore the cooldown settings. The printer will wait for BOTH extruders to stabilize at full power. Again, it should only do this for the active extruder.
You will see this at the start in the G-Code:
When setting different extruder temperatures at different layers, Simplify3D will ignore the cooldown settings, and any extruder listed for that layer will be set to full power when that layer starts, even if it's not the current active extruder.
You will see this after the specified layer starts in the G-Code (in my test this was layer 2):
These bugs cause oozing, and make Cooldown extruder while idle pretty useless. I spent a day battling this trying to get things to work properly and gave up on using Cooldown extruder while idle. It would be great to use it. It's a useful feature. But these bugs ruin it.
I was able to get around these issues by using other tricks to force the active extruder to be on at full blast and the inactive one to be set low. I got it working, but it's hacky. See here: viewtopic.php?p=74449
Code: Select all
M104 S220 T0
M104 S220 T1You will see this at the start in the G-Code:
Code: Select all
M109 S220 T0
M109 S220 T1You will see this after the specified layer starts in the G-Code (in my test this was layer 2):
Code: Select all
M104 S220 T0
M104 S220 T1These bugs cause oozing, and make Cooldown extruder while idle pretty useless. I spent a day battling this trying to get things to work properly and gave up on using Cooldown extruder while idle. It would be great to use it. It's a useful feature. But these bugs ruin it.
