I seem to have broken my sequential print. fix?
Posted: Sat Mar 22, 2025 3:07 am
I have a bunch of parts to print with one sequential routine.
Each set of parts has different settings so different processes. easy enough. the last part is a vase mode print.
SO I need multiple continuous processes with a sequential end process.
Basically everything prints continuously except the TUBE which is printed separately (sequentially) at the end
BUT I can't have the other parts sequenced as there would be obvious collisions.
Normally this is very simple in S3D just GROUP the cont processes and leave the last part a separate process from the group.
S3D then does the group first as "one object" and then does the sequence to the vase tube. I know this works. I Have been using it for years and it worked 60 minutes ago and I did it with this very file last night. worked a treat
but now it "stopped" working for some reason. the CLAMPS appear to be a separate sequence for some reason. I even deleted and recreated their process. no joy. you can see this because the SKIRT is not unified. its 3 skirts instead of 2. This happened after I made an overhaul of the files and inserted them to re-slice. the CPM factory works fine but the new one CPM NEW does not work. ideas?
What did I do to break this? how do I fix it?
